Velos880 Setting
sacha
If you are using a spirit pro on your velos880. Please share your settings.
Sacha
sacha
No one willing to share the velos880 settings ?
I installed the 3 blade tail upgrade and now have some tail oscillation.
Increasing or decreasing the gyro sensitivity between 70 - 100% does not solve the problem.
Thanks for your help
Sacha
Reducing Pirouette consistency should help if you are observing oscillations just in a demanding manouvers.
There are not too much people that are flying with Velos.
Also make sure that the new upgrade is working really smooth. You can try this in the way, that you unmount all blades.
Then disconnect push rod from the rudder servo so you can move it by hand.
Then you have to start the motor to your flying RPM.
When the motor is spinning, try to move with the push rod - it should be very smooth in the whole travel range. Nearly same as when the motor is not spinning.
