Binding
bill rob
Im trying to set up standard unit on my 450,,Ive got a spirit set up on my logo with spectrum and two sattelites,on the 450 its pwm wiring.
I cant get my receiver bound,,im trying to bind so I can set up my esc then set up spirit.After two hours Im giving up,I must be doing something wrong somewhere.Ive followed the picture for wiring,got the bind plug in receiver and got power to the receiver but no joy,,I cant even get the spirit system to connect either,,ARG!!
I`ll come back to it later,but if anyone has any tips or things to check Im all ears
thanks
Bill
If you are binding normal receiver, you have to put a bind plug always to the receiver (BIND slot), not the unit.
Then it will work immediately.
bill rob
Hi Thanks for your reply,,I have the bind plug in the receiver,spirit light comes on and receiver is lit solid red,I`ll keep trying
What receiver it is? Is a satellite plugged in the receiver?
Receiver and satellite should start flashing immediately after powerup.
It is completely unrelated with the unit so it might be even disconnected.
bill rob
Reciever is spectrum AR 6200,,I think I will just order 2 sattelites and set it up the same as my logo
thanks for your help
bill rob
I had satellite plugged in to receiver,when I powered up receiver and satellite lit constant light
That is really strange. Is the BIND plug good? Maybe there is no connection between two pins.
bill rob
I`ll check it out
