Voodoo700 - Low RPM!
Franky13
Hello Tomas!
I have a Voodoo 700 only for low RPM !
Wich settings are important , especially for low RPM .
my speeds : 1000-1250
Is there something to be noted in the rescue ? They should react in low speed fast!
Greeting Frank
make sure that your Cyclic Ring will be not so high to not get a boom strike.
Also I recommend to set Flight Style to a higher values and Elevator Filter most probably too.
Little bit of Revomix (value 2-4) might be necessary.
Franky13
Ok, thanks!
What is the best Heli in "Setup with wizard" for my Voodoo700 for Low RPM?
(I am waiting for my Spirit Pro!)
Greeting Frank
