No throttle in software
keeny
Hi Ive recently tried to set my 450 fly barred heli up with the new software and firmware.
now nothing has changed from my old set up regarding pwm and rx however i no longer have a throttle response in the 2.1 software, but the throttle works fine.
I'm using a futaba radio
Any help would be appreciated as i have another 3 helis to update.
Cheers Chris.
if you are using PWM connection, then you can't see a throttle in the software, because it is not connected to the unit at all.
It is connected only in the receiver and thats OK.
With older version it was very same, so nothing is wrong in this case.
If your throttle is working well, you do not have to worry about it.
After update to the version 2 (from version 1.3), you have to reconfigure few important parameters - see the News section/2.0.0 announcement.
If I can help you in any way, let me know.
keeny
Ah Many thanks, i must of forgot that :oops: Ive been trying all sorts to get it to recognize throttle........my bad.
Cheers Chris.
