[iOS App] Bug report
This thread is used for reporting the app issues.
iOS app that is currently in the testing via TestFlight.
jgiannakas
Some general layout issues on ios9 iPhone 6:
Also application crashes after clicking connect:
Thank you very much for the report.
Actually the wizard shouldn't be accessible at all (at the moment).
How did you entered it? :)
jgiannakas
It's on the first screen when I open the app!
Guess you've got a config value not being reset on the build :)
jgiannakas
On the iPad it's much better layout wise. However here if I select switch to demo mode = no then all the buttons are enabled (they are disabled on the iPhone). Taping on any crashes the app.
Oh and in both iPhone and iPad there is no demonstration mode button visible!
Thorvald
Same issue on my iPhone 6 (layout). The wizard started right away.
I also just ordered the Wifi adapter today, so should be able to properly test it once that arrives.
Cheers
Tim
Thank you for the reports.
Tommorow new version will be published with fixes for some issues (described in the changelog).
jgiannakas
New version - some layout issues with iPhone 6.
Also the app does not fill the screen. Wifi module is coming tomorrow so will test the rest of the screens then!!
Horizontal scroll bar:
Button labels:
Working well in landscape
But then this screen displays scroll bars:
jgiannakas
Wifi unit arrived.
Connects OK with the mobile app.
Bugs:
1. Layouts on the screens are unusable at present on iPhone as they all show scroll bars etc and need to switch to landscape/portrait to get the content to move to the right place
2. Haven't tried it functionally in detail but the bug I've seen so far was when clicking on the governor button it crashes the app.
Thank you for the report.
You can easily move with two fingers the screen if there is a scrollbar.
Vertical scrollbars are OK, but horizontal shouldn't appear. We will try to fix it today.
We are testing on iPad, everything fits there and is good so iPhone reports are helpfull.
