[SOLVED] Updates for all Spirit FBL's?
berley114
Hi all,
I have x3 Spirit FBL units bought during 2015 of which are at V1.2.0, i have seen there are now more updates to V2.0.1 ? can someone let me know if these later updates are applicable to my Spirit units as i believe the later updates i.e.; V1.3.2 have a different file extension.
with thanks
Kim.
Spirit Warp 360. Spirit Goblin 500 Sport. Spirit Trex550 DFC. (BeastX Trex450, BeastX Trex550e... in Thailand)
Blade 270CFX, Blade 180CFX, Nano CP X BL.
neXt-Heli, DX9 B.E. DX6 G2.
yes. It will work without any problem with your units.
You will only need the latest software.
Very probably you will need also this:
http://spirit-system.com/phpBB3/viewtop ... =20&t=1236
Have a nice day!
berley114
Thank you for your quick response.
All of your updates so far there has been no need to do any changes or adjustments, i always check through my settings after updating, are there any adjustments required after the updates from V1.3.2 ?
Thanks again,
Kind regards
Kim.
Alyon187
If you go to version 2.01 then you will need to read the changes and make sure all your servos are in the correct slots, the orientation of the unit is right and the swash is orientated correctly as well. Also make sure your channel inputs correspond to the diagnostic screen direction. Using your TX default settings is recommended.
Please read release notes of 2.0.0 - available here in the News section.
There you will find what is needed to change.
Also during the update, window will appear where you will see the instruction what you will need to change.
berley114
I am very happy with my heli's performance on the present V1.2 but, i will apply the recent updates as soon as possible.
Thank you all for your help.
Kim.
