Spirit Wifi-Link
Posted: Sun 22. May 2016 22:06:38
by ajadda
I do not own a Wifi-module yet, but I am wondering what will happen if there are more than one Wifi-modules active.
Are there different SSIDs? How is the IP-address determined?
The app shows WIFI [ 192.168.4.1], is this a fixed IP-address?
Are parameters such as IP or SSID modifiable?
Regards,
Alexander
Re: Spirit Wifi-Link
Posted: Sun 22. May 2016 22:14:04
by Coco66
Once you connect to a Wifi-Link and get to 192.168.4.1 with a browser, you can change the SSID so to differentiate the different units you have and use understandable codes ("Spirit_Warp", "Spirit_G500" a.s.o.).
Not sure if they have already natively different SSIDs, but the IP addresses will always be the same anyway in each network, so 192.168.4.1 will always connect you to the WiFi-Link module of the network you are connected to.
Posted: Sun 22. May 2016 22:55:21
by ajadda
OK, I understand, thank you.
An initial common SSID is no problem if the SSIDs can be modified. Hope the corresponding password can also be modified
This way there is no problem using the same IP-address for all units.
Regards,
Alexander
Posted: Mon 23. May 2016 7:19:17
there are different SSIDs by default, similarly to BT modules.
You can modify it in the settings in any way as you wish.
IP address (AP side) is always 192.168.4.1, but in case of Client side (if used) the module will obtain a second IP in dependency on your network.
You can find these information in the PDF guide.
Posted: Mon 23. May 2016 20:23:18
by ajadda
I found the manual in the download section of the shop.
The procedure(s) are understandable to me, thank you.
Best regards,
Alexander
