Can Wifi link be operated while flying?
igloo
Since the operating range is expected within about 30 meters, could it be possible to use it while flying for, as an example, reading the spectrum analyser log on air, the gov rpm, the log viewer... provided of course to be two to do it.
That implies also that these optional possibilities do not trouble in any way the module main goal : heli stabilization. Has this been already tested ?
Coco66
For sure not the Spectrum Analyzer since it locks the servos in current position when you enter it!
At the moment it is same as with BT module.
You can ask manufacturer of your transmitter/receiver if can be operated with WiFi without an interference.
If so, you can use it while flying.
Our WiFi module allows many things (because of support for updates). So later it might be fully supported .
igloo
Tks a lot. I think I will give a try.
