Hi... I have an Problem with my Spirit.
There is an Delay on Pitch. When i move the Pitch Stick it lasts about an half Second before something Happens on the Helicopter.
I already changed the Receiver but was the same.
Then i made an Factory Reset and updated to 2.0.1 but was still the same.
The movement in the Software shows no delay.
My Setup is:
Goblin 380
Futaba T10J with Frsky Delta 8 on S-FHSS and PPM
Spirit 2.0.1
Hobbywing Platinum 100a V3 LV with int. BEC on 6V
Swash Savöx SH-0255MG
Tail Savöx SV-1275MG
Motor Scorpion HK-3020-1000KV
Greetings Sebastian
Delay on Pitch
Here it is...
- Attachments
- goblin380.4ds
- (255 Bytes) Downloaded 114 times
according to savoöx (http://www.savoxusa.com/Savox_SH0255MG_ ... 0255mg.htm) your cyclis servo is 200-250 Hz, and currently you have it at 60. ( it should not do this at 60, so i dont think it will solve this )
Also for tail i think the 9 delay is too much, and according to savöx the servo max frequency is 333hz, set it, on small heli it can make a difference.
And i think elevator filter at max 4 is too high, i use 3 on 700 heli, and usually big helis need higher number.
I cant see any more abnormality in settings, maybe Zexx will be able to help you more
The 60hz is because of i used another set of 0255MG at a Trex450 with 200hz and they ran very hot and noisy. So i checked the Beastx Servolist and there they were listed with max. 65hz. After lowering the Frequency i had no Temperature Problems anymore.
You mean that when you are in Diagnosti at full negative pitch, you move the stick fast to full positive, the bar on the screen moves accordingly but the swash stays for half a second then it moves correctly?
Do Elevator and Aileron behave correctly?
