3 Bladed Head Oxy 3 Set UP
nixtrix71
Hi All,
I was wondering if any out there is using the Spirit with the Oxy 3 Cube which has the 3 Bladed head system.
I am just about to set up mine and before doing so was hoping someone out there has already done so and could maybe help with the general set up, before tweaking :roll:
Hope someone has knowledge about this and maybe is the same as the normal set up but just to be sure :D
Thanks to the team and support and for the great FBL system.
Nik
yes, there are some pilots with this setup. In the Support settings there were some questions, but overall there is nothing special in the settings.
It is very similar to 2 bladed setup. Gyro Gains can be decreased little bit.
nixtrix71
Thanks will go ahead with the set up.
Will try standard and if need play a bit with the gains :mrgreen:
