Unit position
Christian Blom
In the unit position display where is the front of the helicopter?
Gtamas
The arrow is the front
Christian Blom
I'am trying to set up Governor in Spirit Pro. It asks for throttle Frequency and throttle range.I have a Jeti mezon 160 w/ rpm How do I find these units to use?-I cant find them on the Jeti website.Thanks for your reply-Chris Blom
For your ESC 120Hz should work good. Default throttle range in the unit is OK.
Unfortunately it looks like this ESC has some delay, so it is question how useable it is for external governor.
In the worst case manufacturer should tell you the values and also best settings for external governor.
