Which rpm sensor for nitro governor
zosek
Hey,
i've been browsing around and found out that everytime one asks this question, the answer is always align rpm sensor. Now, i've been searching the online shops but i haven't found align rpm sensors in stock anywhere. So what are other good replacements for rpm sensors. Spartan? I have at home gv-1 sensor (currently using gv1 governor), does this sensor work with spirit or only futaba?
Thanks.
Dawiev
I believe the sensor works with Spirit indeed. As you have the governor, you can power it up and make sure you get max signal strength from the sensor and then remove it
This will eliminate any arguments about signal quality
