Settings for yge and spirit gov
torro
Is There a special setting for the yge Esc?
Mode 1 for external gov.
Hints or tips?
Thanks, Flo
torro
Yge120lvk V3, scorpion hk 4220 torro Edition, diabolo 550 @6S
There is nothing special for YGE. You can just set Gov Off and use default throttle range 1100 - 1900us.
Then it should be fine :)
torro
i just programmed a YGE 160HV ESC. i had to set the throttle range to 1000-2000 that it worked.
YGE said 1100-1900 should be fine.
@1100-1900 i could enter the setup in ESC (full throttle, after beeping stop), but the next time i had to go full throttle, the ESC didn´t react to it.
any idea?
Best regards,
Flo
this is beacause each time you are doing this procedure, you will recalibrate throttle range of the ESC.
So by this you have to increase the throttle range again.
You should not do this procedure when using Spirit Governor.
The best can be if you can do the factory reset of the ESC. But with YGE it is not too easy and procedure is not documented.
Or you can simply increase the range again.
