Spirit Mezon with wrong esc singal. Dangerous start!
Speedy
hi,
i use spirit with Jeti Mezon.
My Mezon is plugged inside the spirit and i use the mezon governor.
If my governor signal from transmitter send 70% because of wrong switch position.
The spirit send 0% til initalize process is finished to the mezon. The mezon initalize!!!!!!
After initialize of the spirit, spirit send the correct valu 70% the mezon.
Mezon is starting the governor and the Rotor start!!!
I think this is very DANGEROUS!
Is it possible that you check during intialization the motor singal from receiver?
Regards Sebastian
when governor in the unit is enabled, it is checking throttle value.
When it is disabled, unit is sending value from the transmitter all the time, as soon as it will receive valid receiver data.
So it is not initializing with 0%. You can verify it with a servo in the AUX port.
