[SOLVED] Setup via WIFI / Iphone 5 problem
Posted: Tue 02. Aug 2016 12:40:04
by Herbierotor
Hi!
Got a problem with the WIFI solution.
I tried to use my Iphone5. It works basically, but I can´t reach the button to store the changes. The field is to close to the bottom of the screen, so I can´t reach it with my finger reliably. Sometimes it works, but mostly not.
Any hints for me?
Many thx in advance!
Kind regards, Herbert
Re: Setup via WIFI / Iphone 5 problem
Posted: Tue 02. Aug 2016 13:04:00
Hi Herbert!
First you have to open the menu (left bar).
This can be done by rectangular icon in the top left corner.
You have just click (tap) on it and menu will show up.
Then in the menu you can press Save Settings option.
All the time, you can use Zoom function of your web browser, so you can make the button very big.
To zoom in, you can use two fingers as you can do usually on a web pages.
Posted: Tue 02. Aug 2016 18:46:58
by Herbierotor
Hi, many thx for your answer!
The use of the menus is very clear for me. There was just the problem, that the button for the Save Settings Option is shown in an area on the screen, where the iPhone will insert a command line if touched. But if I use the zoom function and make it smaller, the distance to the bottom line will be higher and the button can be reached reliable. Problem solved
Posted: Tue 02. Aug 2016 20:25:18
You are welcome!
That is great. Maybe you can try to use other browser or a landscape mode - it can be more accessible.
On a bigger displays such as iPad has, menu is visible all the time.
