Rudder channel not working anymore.
dimisx1
Rudder channel is not working anymore after updating to 2.1.0 everything was fine until now but after updating the ruder channel is dead! It will make the servo jitters like crazy for some seconds and after that nothing is happening! I have tried 3 different servos different servo settings but nothing!! It was fine before and the update went flawlessly. The tail servo works in other ports but not at the rudder port. The unit is connected direct with satelite receivers with a new dx7. I also tried and setup with the sbus port with a Futaba of a friend of mine but still nothing! Has anyone had this problem or my unit has gone bad??
please try to reconfigure parameter Rudder Dynamic to other value and then return back and save the settings.
Are you using Android app?
You do not have to post the question to our email and this forum at the same time.
