Ds 14 jeti, what rx for you to use the rescue Hello everyon
Posted: Wed 31. Aug 2016 19:04:59
by jconcept
Hello everyone, I'm new here ...
I used the Spirit in SBus Futaba carefree, but now .... I swim with my DS14
What RX can be used for 8 channels and the rescue? I only arrived seven tracks with rex7
Can I use Live duplex sat PPM?
Thank you for your help
Joel
I try to talk to the translator, not easy sorry
Re: Ds 14 jeti, what rx for you to use the rescue Hello eve
Posted: Thu 01. Sep 2016 7:21:17
Hello!
Welcome in the Spirit forum!
For Jeti DS-14 you can use any Duplex EX or REX receiver. All support integration with the Spirit unit (configuration through the transmitter menu).
If you do not use any additional telemetry sensor, then it probably does not matter which one you will buy.
Connection with the unit and receiver should be configured to EX Bus. So it will use EXT port in the receiver (or E1/E2 with some REX receivers).
You can use for example Jeti Rsat2 or REX3. These are small receivers that should be enough.
Posted: Thu 01. Sep 2016 10:09:11
by jconcept
Hello
Thank you for your reply, I tried with my Rsat with Spirit on 6HVU
Posted: Thu 01. Sep 2016 19:54:53
by jconcept
Hello ,
For the moment all works EXCEPT motor (I can not find how to harness the engine) .... On the ca REX7 works, but on channel 1 and all the rest EX.
With Rsat .... I look back and
JF
Posted: Tue 06. Sep 2016 18:17:20
by jconcept
Hi everybody
A can of niews, Afterwords you buy a R9, the all works perfectly!
Thank you for your advice, for longer use against my helicopter ...
I copy a file in .bin Jeti my DS14 and great BUGG, the RX does not work at all!
The dialogue does not look easy in case of trouble in Jeti, although unfortunately ....
I apparently expect a mail from an engineer at Jeti will be seen in time.
JF
Posted: Tue 06. Sep 2016 22:07:42
can you please explain the problem in more details?
Maybe we can help too.
Posted: Wed 14. Dec 2016 21:42:59
by snowflake
Depending upon the amount of telemetry devices you wish to connect, determines whether you use a regular Duplex Rx or a Rex Rx. As Tomas indicated, you use a single wire on the EX Bus output of the Rx. All channels can be configured to appear on the EX Bus. Furthermore, you can also use the extra Rx channels (other than the EX Bus port) for any other non-Spirit connections that you might wish.
I used a Jeti R3 Rx with my Spirit Pro; one of the channels configured (using Jeti Tx Device Explorer) to EX Bus, and the other two channels to control other devices not of interest to the Spirit Pro.
The trick is to assign the channels that the Spirit requires using the Device Explorer "Receiver Output" screen.
For my latest project, an Extreme Flight 65" Turbo Bushmaster (AKA Bushbaby), I switched to an Rex 7 as it is the smallest Rex Rx available in the United States (FCC certification.) I did this because I want several sensors to report back via the EXT port(s). The R3 EX Bus port is the "Ext" port, so no external telemetry is available; hence the Rex Rx.
EX Bus will allow as many channels as the Tx can support, but the Spirit in "Aero" mode, requires seven, at most (if using a channel for sub trim setting.)
I believe that Tomas provides the appropriate ".bin" file to Jeti and that is available for download. I have not had any problems interfacing with my Spirit Pro via my Jeti Tx (DC-24 and DS-14.)
Michael
jconcept wrote:Hi everybody
JF
