Spirit wifi won't connect with app, does connect with the we
velocity90
After the 2.1 update my spirit won't connect with the app. It will connect thru the webserver ip. The Blue led is always flashing slowly even when connected to the wifi which I always do first.
you have to also update the wifi link module.
velocity90
I did, will try again
velocity90
Im not getting a wrong version message
That is strange. Is the module powered from the same power supply as the unit?
Is it connected as described in the Wifi-Link guide? Connection is very same as for the BT module.
velocity90
Yes, it used to work fine, but with 2.1 the app won't connect anymore
I think that the problem is because you have received pre-production version of the module which was not configured in the same way.
I will send you PM.
velocity90
Answered your pm :)
