Align T-Rex 500 PRO DFC
motor Align 500MX (1600KV) + 12 pinion
serva 3x Align DS515M, 1x Align DS525M
Spirit System + Align 500 PRO DFC head
regl. Align RCE-BL70G
baterie 6S 40C 3000mAh
křivky, cca 2600rpm. + - 12,5 st.
listy Align 3G FBL 425D
POZOR!!! JE TŘEBA ZKONTROLOVAT SMĚRY KOMPENZACE A VÝCHYLEK SERV!!!
Na vaší heli a s vaší výbavou mohou být jiné.
Align T-Rex 500 PRO DFC 1.0.23.4ds
(255 Bytes) Downloaded 429 times
Romis
How much rudder revomix to use on a T-Rex 500?
For T-Rex 500 revomix is normally not necessary if there are stock servos, motor and blades.
Altough if you are unable to get proper performance without it, value of 2-3 may be fine.
Bladetip
How do you open these files?
You can just click on the magnifier icon here.
Bladetip
Thank you!
