[SOLVED] Governor: Gear Ratio to small for larger Scalers
SnakeEyes
I just found out that the gear ratio in governor settings is limited to 1:12.7.
Gear ratio of the HSM800 mechanic is 1:13.83. And thats not the only one beyond that limit.
That means I can't use the Spirit Pro governor properly because I can't set it up correctly.
Please increase that range!
Best regards, Thomas
We will fix the problem soon.
Right now you can use workaround that will work in the same way as if you enter the correct value.
You can simply change Sensor divider. Governor is using this only for RPM calculation, which is evaulated by
Gear Ratio * Sensor divider.
If the result will be similar with other sensor divider and gear ratio, then result is the same.
Let's say you have Gear Ratio 4.
4 * 13.83 = 55,32
5 * 11,05 = 55,25
This mean that 11,05 ratio will give you same result as with 13,85.
SnakeEyes
Thank you very much, that will do for me!
