No entry at logfile after failsave
Posted: Fri 30. Sep 2016 22:51:32
by scvflyer
Hi serviceteam,
I had a failsafe situation but i didn't find any message about it at log.
Is that as designed ?
br Siggi
Re: No entry at logfile after failsave
Posted: Sun 02. Oct 2016 12:18:52
are you sure that Failsafe was activated?
Normally if there is a signal loss, the unit will always log the event and then you can see it in the "previous flight" log.
You can verify it on the ground just by turning off your transmitter and then power for the unit.
Then you can connect the unit back and view the log.
Posted: Mon 03. Oct 2016 19:56:09
by scvflyer
yes I had failsafe situation definitley because it works as configured - that's fine.
Reading your sentence i guess I did a mistake - small one but it seems to be important.
I powered my system on - that menas completly with TX and so on. And you wrote, as in understood - just power on the spirit unit - is that right?
br Siggi
Posted: Tue 04. Oct 2016 8:38:20
by Coco66
I think Tomáš suggested to proof the logging will behave correctly by creating a failsafe situation on the ground (with blades off).
Turn off the transmitter, failsafe kicks in, turn off the Spirit, turn on TX, turn on Spirit, check the log...
