[SOLVED] Spirit Pro sometimes doesn't connect to transmitter
UFOking
I have 2 Spektrum DSMX satellites connected to my Spirit Pro and they sometimes won't connect to my transmitter.
When I connect the battery, the lights on the 2 satellites start to blink as if they were in binding mode.
I than have to reconnect the battery to get a connection. Sometimes I have to reconnect it more than once.
I also have a regular Spirit with also 2 dsmx satellites and never experienced that...
Thanks!
that is interesting. Do you have something connected in the ELE/PIT/AIL or SYS port when it happen? (For example some module)
This could possibly trigger the binding procedure.
UFOking
yes, the WiFi module is connected to SYS port.
Ah, in this case - is the WiFi module updated to the latest version? If no, then the problem is just there.
UFOking
Indeed it is the WIFi module.
I disconnected it from the SYS port and and it connects with my transmitter every time.
But the funny thing is, that the module is updated to the latest version.
Hmm, thats strange. Can you please verify with the web browser, what version you can see there?
You can connect to the module with PC or smartphone and enter the web page: http://192.168.4.1
Then you should see the version.
UFOking
I see version 2.2.0
UFOking
any news about my problem?
Thanks!
we have modified the firmware to be less sensitive for binding, but this change will show up in the next version.
If you are interested in testing it, we can provide you the firmware right now.
UFOking
OK, Thanks!
