Power supply
Clinton
Hi guys. I've got my first pro which I am going to install on a logo 600. I'm using the ar9020 srxl connection . I have two leads coming from the kontronic esc for power. One goes to the throttle on receiver. Do I put both in receiver or one to the fbl unit. Or both to the fbl unit.I will be using the kontronic governor. Thanks in advance
Hi Clinton!
All the combinations that you have mentioned will work.
But to avoid ground loops, the best way is to connect throttle directly to the unit and second lead of the BEC too.
So AUX1 and AUX2 will be for throttle input and powering.
Receiver can be connected just with a single cable as it require very small current.
Alternatively you can connect BEC and throttle to the receiver and use two cables connected to the unit.
