[SOLVED] Jeti device explorer
andreasdahl
Hello, just a simple question. When I go to device explorer in my Jeti Ds16 it displays spirit and after (1) or (2) or (3). At first I guess that it was active bank but I dont use banks so what do the numbers means?
Reegards
Andreas
Skickat från min iPhone med Tapatalk
Hello Andreas!
These numbers are only device identifier from the Jeti transmitter.
In case that there are more same devices it is usefull, but when there is just one, it has no meaning for you.
In this way you can distinguish which device is which if there are e.g. more Spirit units.
So you can simply ignore these numbers in your case.
andreasdahl
Thank you for the clarification[emoji106]
