[SOLVED] EX-Bus / Jeti / RPM signal?
gabs_mex
I just purchase a Jeti, and im planing on using the EX Bus for the integration, my question is this, if i use EX Bus i loose the Governor of the FBL, is this correct?
I will have to use the PPM on the reciver to free the input of the RPM signal and only then i can use the Gov, is this correct?
or can i use EX Bus and use the middle pin that is free to get the RPM signal and use the GOV?
No, you can use Governor with EX-Bus with no problem.
You can use the PIT pin (middle pin) as described in the manual.
You can also use UDI protocol with Jeti, but with EX-Bus you will get full integration.
