[SOLVED] Devo 10
Jimbo
What is the transmitter set up for a Devo 10 using Deviation firmware? I have a Spectrum satellite receiver, in a Trex 250.
Jim
Unfortunately I can't say you a details, but there shouldn't be anything special except that the swashplate mixing must be disabled (H1).
This mean that movement of a stick will move just with a single channel.
You will need to bind the satellite in a 22ms mode, else channel reading will be erratic.
This can be done with a bindplug in the SYS port for DSM2 22ms or bind plug in the SYS and next in the ELE/PIT/AIL for DSMX 22ms.
Then only important is to reverse channels so that movements will correspond with movement of the bars in the Diagnostic tab when doing setup.
This is very important.
You can also use Expos 20-30% if you like it.
Nothing else is needed.
Jimbo
ZeXx86 wrote:Unfortunately I can't say you a details, but there shouldn't be anything special except that the swashplate mixing must be disabled (H1).
Thank you. I look forward to trying the FBL.
Jim
