[SOLVED] Using sliders on Wifi module
felixthemaster1
I just received my wifi module and it works pretty well! Kind of annoyed that I need to take out one of the sats to give it power, but it will works regardless.
I was going through the menu and it seems very simple, and works well. But I tried going into a slider setting (rudder limits) to check how reactive the settings are. It is fairly unresponsive (Google Chrome). It would be a lot better if you could see the value on top as you slide the finger so you can precise stop at the wanted value
Is the app a better way of doing this? Will I need a bluetooth module to use the app, or can I use this module?
the response should not take longer than 100ms. But if you are using a mouse, then it will always send the value when you set it at something, not during a movement.
I recommend to use key arrows. With this the response is instant.
Unfortunately this is something that is processed by the web browser - each is handling it differently.
But we are working on the update where the sliders will be improved :)
With PC app & Wifi module it is working in the same way as you know with the USB interface.
buell47
Android App and WiFi-Link works great also [emoji4]
Jeti DS-16 Red Carbon+REX7
felixthemaster1
Btw the Chrome was on my Android phone, haven't tried it with a computer yet.
But it's good to hear that it works with the app, thanks :)
Also, can't wait for the update!
Update released :)
