[SOLVED] Throttle in rescue function
tzirancamaro
I would like to know if the rescue function increases the throttle output from the unit to maintain the speed of the airplane during ascend, in order to avoid a stall, or it is necessary that the pilot manually accelerates the motor to keep the air speed
Thank you
you will need to add mix for the throttle for this operation - When Rescue is active -> add throttle.
This should be easy to do.
But for all receiver connections where throttle is connected to the unit it is technically possible to do.
So we can implement it in the next update.
tzirancamaro
Thank you very much, I hope that the next update will include this function
