Spirit and TDR II
kineteks
Can you confirm the the Spirit FBL is suitable for the linear servo system in the TDR II? Is there a software setting to disable compensation for non-linear servo movement?
Yes, with Spirit FBL you do not have to disable anything.
It is only needed to reduce Geometry 6° by approx. 1/4 (after you will find a precise value).
Then set the Elevator Filter to 4.
