[SOLVED] Main Loop Hang error in Log
Malc1
Any idea what is causing the Main Loop Hang errors in the attached log?
Previously mentioned elsewhere.
This is a Brand new Spirit Pro set up on the bench with only a Scorpion ESC (with SBEC), Jeti Receiver connected EX bus and a Scorpion Opto cable.No servos are attached at this time.
This is with the setup only switched on and left alone. TX is not touched.
The Spirit USB cable is also not attached to the unit.
spirit-log-2017-01-16-235339.pdf
(80.55 KiB) Downloaded 132 times
Malc1
And with out the Opto cable plugged in and powered up.
Again just a receiver and battery pack connected.
spirit-log-2017-01-17-003549.pdf
(84.87 KiB) Downloaded 128 times
can you check what will happen when you disconnect the receiver so there is completely nothing just the unit?
Do you use our special firmware that I have supplied you?
For sure it is not OK - the issue could happen when e.g. too high voltage comes to unit through RPM sensor, but when you are it is happening also without Opto cable. So I guess that this is not the case.
Malc1
Still get the same message when unit is powered up using a 2S lipo, so no supply from the ESC.
And get same message just after initialisation without the Jeti receiver plugged in, just powered up using a battery.
Doesn't seem to be much else actually recorded with this though or no log at all.
Using supplied firmware.
I can send you a new firmware (or you can use the official).
Malc1
All now sorted :)
Great! You are welcome :)
