Spirit Profile Beta error
Coco66
Current Spirit Profile Beta prints "Servos ‐> Subtrim ‐> Pitch (CH1)" value of "66" while the value is actually "-66" in software "Spirit Settings v2.2.0".
Used to work fine at least until 19-DEC.
Thank you for the message.
We will check it. The software (Spirit Settings) is doing a special reversing depending on the servo reverses, but in case of the viewer it is displaying a raw values (unmodified).
Coco66
http://4dsviewer.spirit-system.com/www/ ... ?_fid=cq8w
http://4dsviewer.spirit-system.com/www/ ... ?_fid=wdui
For both files, Spirit Software actually shows -66, while the 4dsviewer shows -66 in the first (older) and 66 in the second (newer).
Nothing actually changed in my setup, as far as I know... I went through the setup to redo the servo adjustments after replacing a broken link but in the end I ended up with the same -66 value of adjustment.
Thank you very much.
This is really interesting.
I will move the thread to the Wishlist / Bug report section.
Coco66
I forgot to say that it's probably not a problem of the viewer, since both files are now viewed with the same version of viewer...
We will verify it tommorow and let you know. It might be related with profile loading/saving.
