Bin Datei Spirit Aero
gerry
Jeti Bin Datei for Spirit Aero
Greetings Gernot
Please write to jeti@jetimodel.cz
Jeti do not want to release the file because Spirit Aero is competition for them.
But sending them questions about it can change the situation.
gerry
Hello Tomas
I understand, will be in contact with Jeti and try to persuade them?
Greetings Gernot
I am in contact with them all the time. We are preparing source codes and they are transforming it to the binary file - file for Jeti transmitters (but only for Helicopters).
So without them, we can't release even that it is done for Aero. But they simply do not want to release it, because they are probably doing own product. And to reduce interest in the Spirit Aero they do not want to release it.
But if they will see that more customers are interested in it, they have to do something (if they care about their customers too). We have integration with FrSky that already support it with Spirit Aero from the beginning. So people might want to switch from Jeti.
So if you will send them message, it could help.
gerry
Hello Tomas!
My colleagues and I are already in mail contact with Jeti, we have already received answers. But unfortunately still no commitment! We will try to build up some pressure. We also have a colleague in Vienna, who works with Jeti very closely He told us this situation. He told us the Jeti is currently working intensively on the FBL System Assist. He is trying to reach for you and for us something. He believes the Jeti will release this bin file!
Supposedly, Jeti has to use the Assist also for helicopters! That would not be good!
I will for the time in between a Bluetooth adapter with you order, is not so expensive. And with the mobile phone at the airfield set, pity, for exactly this reason, we sold V Stabi and have changed to Jeti and Spirit Also Jeti written.
I hope everything will be fine!
The colleague from Vienna has said that he would have in an emergency the possibility to adjust the existing bin file on Aero.He knows someone in Norway who does that!
Greetings, Gernot
Greetings Gernot
Very interesting.
Thank you for the message!
gerry
Hello Tomas!
That was the answer from Jeti, they say they have no data ??
Hi Gernot,
we don't have Spirit aero bin.
Jeti Modells
But we've got the thing started, some people are confronted with it, maybe you're giving them the data again, and who knows, maybe it's what's causing some people to confront Jeti!
In any case, We do not give up!
Greetings, Gernot
Greetings Gernot
Thank you very much for the message.
Yes, they have no BIN file, because they do not want to create it. We have get answer that they simply can't do it, but no reason was stated never.
We will send them the latest source code that they can use today.
So if they want, they can release it today or tommorow for the latest Aero.
We have sent them the latest Aero source code required for the BIN.
Here you can see screenshots from the Emulator where we can at least test the code.
So in our side everything is finished for long time.
Adrian
Interesting reading, I was planning to move my Radio Base from Spektrum to Jeti due to Spirit integration.
But this project got a full stop now. I need to review and take a closer look into FrSky.
Thanks for the open communication, Adrian
