[SOLVED] Graupner Hott SumD / Telemetrie
nenno
Hi...
I have a issue with SumD. When i plug in the accu the Spirit calibrates but the Swashplate pumps 6 times.
After that i can't move pitch. Ele, Ail and Rudder are moving. I made i clean Setup with my MZ24. Channels are moving the correct way... but Pitch is shown as channel 6 and throttle is shown as channel 1. This is not the correct channel-order for Graupner...
Telemetry integration is working. I use a Unisens-e in parralel. I have only one issue in this combination. I can't enter the Unisens Setup (Unisens is configured as ESC-Sensor). The Setup Menu is not shownm, but the Unisens-E Telemetry-Data is shown. Don't know if it's a problem with the Spirit or the Unisens.
Regards - Jens
Voodoo 600 - Compass Warp 360 - Mikado Logo 480xxtreme - FrSky Horus X10S express
TomasN
Deleted
great!
This problem is caused, because you have enabled Rescue mode.
So when you will deactivate rescue, it will work.
Probably only Gyro Gain is not configured.
Here you can see description and solution of your problem:
http://manual.spirit-system.com/index.p ... _Solutions
Regarding channel mapping, in Spirit there is a different channel numbering, but this is absolutely correct. So you can leave it as is.
You only have to change Gyro Gain (increase) and then all will be OK. Probably it is at default value - 0%.
buell47
You have probably rescue activated the whole time.
Jeti DS-16 Red Carbon+REX7
nenno
buell47 wrote:You have probably rescue activated the whole time.
You where completly right. My Mixer for Gyro-Channel Reverse was in the wrong way, because the Channel travel and reverses are now in the right way for Graupner...
Thanks for the quick help...
Regards - Nenno
No problem.
You are welcome!
