Detailed informations how to connect ESC
Ortie
As I read many people have problems to connect ESC to the Spirit and get it working.
It would be fine to get detailed informations on Hobbywing, castle, etc
thank you. We will try to improve it.
But there is only one way how you can connect the ESC to the unit.
Just plug the ESC to the AUX port and thats all. It is same for each ESC.
Then go to the General/Channels and assign Channel 1 to the Throttle function. From this point everything should work.
Ortie
ZeXx86 wrote:Hello,
It might be that it seems easy for you to assign Channel 1 for the Throttle function, but I got in channel collision.
From my point of view in the BD it is to connect the ESC to the unit.
All leads (gas and BEC) you have to connect to the unit and that is all....
