stabi/rescue using assigned channel/switch
andy6409
Is it possible to have stabi and rescue on a switch using the new channel selection method, for example stabi with switch off and recue with switch on so I am always flying in stabi mode
At the moment I am using banks to give me stabi acro on bank 1 and rescue on bank 2 and have permanent negative gyro gain to activate it
when using method described here: http://manual.spirit-system.com/index.p ... te_channel
then negative Gyro gain will not activate any of these modes (it will be switching only between Gyro modes) as described in the table.
Yes, you can use Banks where for each bank you can select a different mode (Rescue/Stabilisation) and then activate it by a channel.
It can be activated all the time.
So settings will be very similar as you have it right now.
