jeti integration spirit aero
berenger
for jeti dc 16 or 24 , do i have to use the file bin "spirit pro" for integration to my transmitter?
please check this thread:
http://spirit-system.com/phpBB3/viewtop ... =36&t=1831
Fortunately you can use Real-Time tuning and tune all important parameters during the flight.
berenger
on the last update of my dc24 there is a spirit.bin , but unfortunatly the answer of transmitter is : error
i have connected the spirit to a r9ex , aileron and elevator are ok , but rudder no (impossible to drive by te gyro)
i have connected direct the rudder on r9 ?
Spirit.bin is for helicopter firmware. But you do not need this file at all.
You will need only EX Bus connection. No additional cable is required.
Very likely the problem with rudder is caused by different channel mapping.
Please set the mapping in your transmitter so it is:
1 Motor
2 Aileron
3 Elevator
4 Flaps or other function or unassigned
5 Rudder
6 Gyro sens.
Then you can start the software and immediately after this channels in the software (Diagnostic tab) should match when you will move with the sticks.
I also recommend to use Setup wizard that is embedded in our software.
