Scorpion Tribunus / Jeti / RPM not riding
gabs_mex
i have a Tribunus atach to Jeti telemetry and the RPM cable from the slave attach to the Spirit and no data is coming out to read the RPM.. is this because Inhave the Telemetry setup to Jeti so it eliminate RPM out from slave??
Any Idea
to read RPM you will need dedicated cable which outputs the RPM (nothing more) - connection usable for governors.
Since telemetry reading from the ESC will be available in the next update, it will not work yet with telemetry data.
gabs_mex
Ok the Tribunus ESC the slave cable run red-black-white / red and black are current, and white is RPM signal, but I think since its program to send telemetry to Jeti maybe it's deseable have to ask them o think.
You should get RPM reading already. But it is possible you will need Scorpion Opto cable as recommended by Scorpion. But I dont know if it is needed with Tribunus.
We have Tribunus here too, so we will test it.
