Normal Rescue and Tail question
lostmyheli
My Align 550 the tail kicks left at take off after that it's fine. What setting changed needed ?
Tried Normal Rescue from inverted for the first time. Inverted nose in after upright rescue heli
is at a 45 degree angle from nose in. Is this the way it should work ? Why doesn't it rescue nose in
like it was before rescue ?
If your tail slider is not in the middle during lift off, then it is quite normal.
Before you will start the motor, always make sure that the tail slider is at the center. And it will not move the tail anymore.
Is the tail working well in other way?
Regarding Rescue Normal - it depends what is closer. Priority is that the helicopter will be in the right horizontal position as fast as possible to rescue the helicopter.
