bad Tailperformance
Bjoern_ve
Hello everybody,
First the setup:
Gaui X3
SP Servos: Servoking 999
Tailservo: Servoking 795i
Blades: Zeal 360mm
Tailblades: Zeal 69mm
My problem is that I turn with Pitchpumps the tail away, I've already tried with all the settings but without success. Now I have gone to increase the speed at the tail and use other blades. Now the Tail holds but I get already with Pitchpumps a tremble, so I must reduce the sensitivity so strongly that everything is again as in the beginning. Someone has an idea.
What I noticed is that I have to keep the sensitivity very low, currently I am at about 20 at the low speed, at higher, that would be already almost 0.
Björn
Spirit Gaui X3.4ds
(255 Bytes) Downloaded 122 times
Gaui X3, Gaui X7
first from all you have to put a shorter servo arm (maybe 2 holes).
Then decrease Pirouette Consistency value to 165-170.
Then increase gyro gain.
And then it will be much better :)
