[ New μSpirit unit! ]
We are proud to announce that brand new unit is joining to our collection! It is μSpirit.
The unit was specially designed for helicopter size of 150 - 180, but can be used even with a smaller and bigger models (up to 250).
Moreover it is perfect for lightweight fixed-wing models as the unit is fully supported by Spirit Aero firmware.
It is made of extremely rigid aluminium AL6082 T6 case, which is even stronger than AL6061 that is used in our other units.
As in case of Spirit and Spirit Pro units, it is purely made by high quality CNC machining.
The best is, that it is basically Spirit Pro, just miniaturized. Same processor, same sensor, same quality. The unit is super small - only 29.3x18.9x8.5mm which mean that it is the smallest full featured unit ever.
And even that it is made by aluminium, it weights only 7 grams. The case is anodized with our favorite color - Red.
Labels are made by Laser engraving so you can read it clearly even with that small size.
It supports completely all features that our Spirit units offer, including Rescue, Stabilisation, transmitter integrations, Wifi/Bluetooth modules and so on. It can be still interfaced also with classic PWM receiver (if needed).
For connecting a peripherals, there are the JST connectors. These are common for such models so that you can get servos directly with them.
If you want, you can use JST adaptor so that you can connect anything with standard servo connector. Some adaptors will be directly in the box, additional can be bought separately.
Available in 1 - 2 weeks.
Pre-Orders are open from now.
Photos of the real units will be available soon!
Nearly here!
