Closing OpenTx Script is not returning to flight regime.
Gunnergolly
To quote the manual :-
3 How to open the Menu
"When script is closed, everything returns to the flight regime".
Ok i just fitted my LOGO 550SX with a integration cable via SBUS (X4R) and i thought everything was working perfectly until i closed the script and noticed that the Spirit was not being returned to normal operation. My rescue was no longer working and i could not switch banks from my TX.
I'm running the script on a X9E Tx with international firmware.
Have also just installed an integration cable on my HD Cell 500 using an FrSky XSR Mini Sbus/CPPM Receiver and everything works fine until you close the script and once again the Spirit is not being returned to normal operation ??.
Only way i can return to normal operation is to disconnect/reconnect the main battery.
Any ideas ?...
Gunnergolly
Ok i found the problem :D .
When exiting the script i must only very very quickly press the exit button.
If i press and hold the exit button for more then half a second the script exit's back to the two main files (basic.lua/special.lua) as expected but does not return the Spirit to it's normal flight regime.
This is repeatable on the Taranis X9E.
Adrian
I discovered similar. After save operation and exit in LUA, Spirit is somehow stuck in Bank 1 and not responding. Opening Lua basic again and going to last page, selecting Bank 0 again and than exit fixes the problem.
Normally the Script is sending command to close configuration.
If this is not sent, then the unit is still thinking it is in the configuration mode.
We will verify how it is working with the latest RC16.
