[ ESC telemetry support ]
We are very happy to announce that completely all our units support the ESC telemetry from version 2.4!
Supported ESCs are right now:
  • Castle Creations Phoenix Edge & Talon (and basically all with Link Live feature enabled)
  • HobbyWing V4 ESCs
  • Scorpion Tribunus ESCs
  • Kontronik KOSMIK & JIVE PRO
  • All other that are equipped with at least RPM lead (RPM readout is already available with 2.3)
With 4 mentioned you have possibility to see Voltage, Current, Temperature, Capacity, BEC Voltage.
It is also very dependent on what the ESC support so that some ESCs may not have e.g. current measurement.
To make everything clear, we are preparing Wiki pages with description of the connection and interfacing.
Our goal is that it is just plug and play, thus you do not have to make any cables. Everything you need is available in E-Shop right now.
You can Log and display all the data directly in your transmitter. We have full support for all the transmitters that already support integration with our units. These are:
  • JETI Duplex
  • FrSky Taranis, Horus / OpenTX
  • Graupner HoTT
The update will be available approximately in 1 week when final testing will be finished.
In the future we will add more ESCs and possibilities to configure and/or display the data. So whatever is missing can be added :)
It will work with:
  • μSpirit
  • Spirit
  • Spirit Pro
Happy Easter holidays!
