Stabi and acro mode both in the DS16, how?
Franky13
Hello!
How can I integrate the stabi-mode and the acro-mode both in the Jeti DS16?
Is there a step by step guide?
Thank you!
I am not sure if I understand your question well - what do you mean by Stabi mode and Acro mode?
Here you can find detailed guide:
http://manual.spirit-system.com/index.p ... bi_mode/de
There you can select which method you want to use. Second method can be easier for you.
We have also prepared Jeti profile (for DS14) where it is already configured:
http://spirit-system.com/dl/jeti/Spirit-DS14.zip
Franky13
Ah, Sorry!
I mean the stabilization-mode (normal) on button SB and the rescue-mode (normal) on button SG in the DS16.
At the moment I have only the rescue mode!
But I would like both (Stabi and Rescue) to have different buttons.
Greeting
MyRCode
Franky13 wrote:Ah, Sorry!
Greeting
You'd have to put those in two different banks.
You could setup a logical switch for one of the buttons that will automatically change banks with one of the buttons, apply rescue mode, and then switch the bank back after the button release.
