First time connect re-occurring !
Van Scott
Being asked by the Software if I'd like to use the Wizard as this is the first time I've connected with new firmware even though I've connected may times and keep seeing this same message !
Is this a known bug or is there something I may have done to cause this.
Could anyone suggest what would cause such an irregularity ?
running 2.3.1 Software and Firmware on a Windows 7 machine.
This problem can be caused if the software has no permission to write in the Documents directory.
Or if there was some issue previously.. If you have file .spirit-wizard, then delete it.
After next start it should be created again and from this time it will hopefully work well.
