Can't seem to activate SL.
Posted: Tue 25. Apr 2017 3:21:02
Have tried to use the SL feature today for the first time unsuccessfully.
I have set Tail Gain in the software and using Banks along with - Negative values for the Gain in the appropriate Banks but saw no SL when in the relevant Bank.
I also fly a BS3SX so was hoping the Spirit offered something that behaved much the same when using
acro stabilization but had no joy first time out. Have rechecked all settings and they all appear to be how I assume to be set up.
Using mixing , the SL Bank will be overridden by the Rescue Bank if needed. All works nicely as far as one can tell on the bench however when I switched to Bank 2 (setup for SL with -70 Gyro in software ) there was very little if any detectable effect on the machine.
Can anyone think of something I could be missing. I'd really like to get it working if it is the same as the BD's SL. Great tool for learning new inverted orientations and alike. Can only imagine it works just as well if I can only get it to work at all.
I require the Heli to SL in normal and inverted flight so have selected Acro SL.
Any help appreciated.
