After update 2.4.0 I hope there is some time for non telemetry wishlist stuff.
For example flying in Stabilization (Acro) and still be able to use Rescue.
All this on a basic (read: limited programming possibilities) transmitter not needing any complex mixing.
Thx!
you can do so easily in these steps:
1. Unassign Channels/Gyro Gain
2. Assign Channel 5 to Banks
3. Bank 0 - Set Stabi/Function: Disabled
4. Bank 0 - Set Sensor/Rudder Gain: 60%
5. Bank 1 - Set Stabi/Function: Stabilisation (Acro)
6. Bank 1 - Set Sensor/Rudder Gain: -60%
7. Bank 2 - Set Stabi/Function: Rescue (Normal/Acro)
8. Bank 2 - Set Sensor/Rudder Gain: -60%
You are done. By switching single switch you can have everything available.
If the radio is little bit smarter, it is possible to assign Rescue activation to one switch and Stabilisation activation to the other switch. Everything with no mix.
If you have any suggestion in what way it could be done, feel free to describe it.
Our goal is to make it as simple as possible so if the change will satisfy all and can make it easier, it will be better solution.
Thx.
I just tried and ended up with a usable setting to test Stabilisation (Acro).
However I have a spring loaded switch with only two positions.
So I used your idea and in resting position it's in bank 0.
When I press the spring loaded switch it's in bank 2.
Resting position, bank 0 with -66% gain gives me Stabilisation (Acro).
Pressed position, bank 2 with -66% gain gives me Rescue (Normal).
(66% tail gain is optimal for my helicopter.)
With this I can test Stabilisation (Acro) and have Rescue when needed.
It does mean I have to take off, fly and land with Stabilisation (Acro) on all the time.
Could this be a problem?
It would be nice to have Stabilisation (Acro) out of the Function drop down menu.
Make it a separate check box or something like that.
That way I can undo all this and use a normal switch to select banks.
(In one bank I will check the box for Stabilisation (Acro).)
Both banks can be served with the spring loaded switch to activate Rescue when needed.
(Function drop down menu in both banks will have Rescue selected.)
Hope I explained it good enough so you get the idea.
- Attachments
- bank2-X3_tail10.5mm_Stab-Acro.4ds
- (255 Bytes) Downloaded 209 times
- bank0-X3_tail10.5mm_Stab-Acro.4ds
- (255 Bytes) Downloaded 189 times
