Konronik Telemetrie
gerry
Hello Tomas!
First of all, I would like to thank you and your team for the great work you do!
I would only have a question regarding Kontronik, the RPM the controller can be processed in the Spirit and displayed in the Jeti transmitter ???
This would still be very important in order to be able to control the different speeds at the heli?
Yours sincerely, Gernot
Greetings Gernot
gerry
Hello Tomas!
What does it mean exactly?
Is the RPM taken over from the Kontronik controller by the Spirit, or not?
Head Speed [RPM] - provided by RPM sensor. (also with ESC Telemetry disabled)
Greetings, Gernot
Greetings Gernot
in the current version 2.4 the RPM is provided only from the PIT pin.
In the next version it will be available also from the ESC directly.
gerry
Thanks for the reply Tomas!
I will wait until the next update.
I am already looking forward to removing the J Log!
How long will it last?
Greetings, Gernot
Greetings Gernot
Right now we are testing the firmware. So it is nearly finished.
gerry
Will the PWM also come?
Greetings Gernot
