Esc telemetry hobbywing v4 60A
torro
Will battery current and consumed capacity be available in near future?
Greets, Flo
unfortunately no, this ESC does not support current measurement, which mean that also capacity measurement is not possible.
torro
Ok, Thanks
torro
Where can ich find this little white plug?
I need to make the cable.
Something special about the pin assignement?
Greets, Flo
You can buy the cable from our eshop.
Connector that is used is one that can be found with Spektrum cables. Normally it is not available in end-user stores.
If you will buy a Spektrum cable it will probably be more expensive than our finished cable.
You need also special crimping tool from JST for the connector.
You can try to find a JST to Servo adaptor cable, the only thing you have to do is to disconnect red wire (positive).
Only ground and signal wires must be present.
torro
The cable is on backorder in your store :D
I have crimping pliers for jst xh and the Standard servo plugs.
The little white plug seems to be much smaller than jst xh. But i could buy a Spektrum cable and crimp my own servo plug on it.
torro
Would this fit?
http://m.ebay.de/itm/1x-Spektrum-Satell ... nav=SEARCH
Spektrum satellite cable 90cm.
Thanks!
