Telemetry Alert (vibration level)
Windsurfer1976
Hi Thomas, since the spirit measures the vibration level, it would be great to set up a telemetry alert, if it exceeds a specified range.
For example, if telemetrie reports vibration level via hott or jeti between 1-13 in flight, one could set 18 as alert limit.
So, if there is a mechanical failure in flying, this could warn the pilot to land.
Hope u understand my suggestion.
Greetings Andreas
Gesendet von meinem SM-G800F mit Tapatalk
Windsurfer1976
I think this could be helpful for scale helis. For 3d pilots, the vibration range would be to wide.
with Jeti and FrSky this feature can be programmed in your transmitter.
For HoTT it is possible only by our implementation - we already plan to add alarms for HoTT, so in future it will be there :)
Thank you for suggestion.
Windsurfer1976
Thanks a lot Thomas [THUMBS UP SIGN][SMILING FACE WITH OPEN MOUTH AND TIGHTLY-CLOSED EYES]
martino
Hopefully, you also plan to implement an alarm for consumed capacity as well ?
Would be great.
Telemetry works nearly perfect with an RCE-BL130A (I miss BEC voltage
but no idea whether or not the ESC provides the data...). On the other hand,
another telemetry screen shows the receiver voltage, so no problem at all.
