Cyclic Gain effect during Stabil/Coax ?
zr1100
Does "Cyclic Gain" in "Sensor" tab affect banks that are enabled for normal stabilization and coaxial?
If so, what is recommended for a starting point--ie. same as on regular flight bank with no stabi enabled?
PS--any tips on cyclic gain range in normal flying mode (disabled stabi) would be welcome also--currently set at 65--on 500 size heli.
you can use the same value as for normal flying.
It is affecting both stabilisation and normal flying mode in the same way - higher cyclic gain - higher precision/stability.
But Spirit can fly well even with the lowest cyclic gain - the feeling is just more natural.
I do not recommend to go too high (over 70%) on this model. Usually value around 65% is optimal.
But you can start with default (55%) with no worry.
zr1100
Thanks very much!
